Budget (including currency): Already know what i want
Country: Czech Republic
Hi, so, i want to build new PC this year, already have everything picked up, but i need one advice, im currently using Fractal Design Torrent Nano case and i will re-use it for my new build, but since its smaller case, i was wondering if 120mm AIO could be better for ryzen 7 9700x, or if i should just get some good air cooler.
My current PC was built on budged, so i have the stock AMD cooler on my ryzen 5 5600. Also i got that pc case for free, and i love how it looks and how small it is, will appreciate every helpul reply c: .
https://linustechtips.com/topic/1615860-120mm-aio-or-air/
Mid-size air is good enough for the 9700X
AIOs are just a hassle and 120mm should be a crime
Ryzen 7 5700X3D (CO) w/ cheap 6-pipe cooler - AX370-Gaming 5 - Vengeance LPX 2x16GB @3800C18 2R - EVGA RTX 3070 8G XC3 PX1  - old Sharkoon case
[PBO2 Tuner] CO -35/-35/-40/-40/-40/-40/-40/-40
[BIOS] Vcore SoC: 1.1 / DRAM voltage: 1.33 (reads 1.368-1.380) / DRAM clock: 3800 / IF clock: 1900 / Timings: XMP
i5-6400 @4.3GHz (160 bclk) w/ Assassin King 120SE - Z170M-Plus - G.Skill 2x8GB 1R + Micron 16GB 2R @3000C16 - Biostar RX 570 8G w/ MSI Armor cooler - old Thermalright case
[BIOS] BCLK: 160 / Core ratio: 27x / Vcore offset: +0.330 / DRAM clock: 2986 / Timings & voltage: XMP
Asus ROG G531GT : i7-9750H (undervolted) - GTX 1650M +700mem - Samsung 16+8GB 2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore: -180 / Vcache: -90 / iGPU+unclice: -50 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753226
A dual tower air cooler will be significantly better than a little 120mm AIO.
I personally cool my overclocekd 9800X3D with a Dual Tower AK620 with a constant low fan speed of 30%.
Same when I had my 7700x, plenty enough to keep my CPU's cool while gaming with little to no noise.
Also air cooling is far more reliable.
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753227
The Torrent Nano will accomodate tower coolers up to 165 mm tall. Which means an excellent cooler like the Thermalright Peerless Assassin 120 SE can be used. It, along with many other dual tower coolers easily outperform 120 AIO.
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753249
Airs are good enough for a 9700X. Thermalright Peerless Assassin 120SE is good for even a Ryzen 9. AIOs that size don't help a whole lot.
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753372
They're a hassle?   If you can build a PC, an aio is easy as any other part.
Much easier than some sur coolers with shitty center balancing bullshit like the 212 Evo.
Yes, 120mm is only super sff builds. Otherwise air til 360mm
Sage: Ryzen 7 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Raven: AMD Ryzen 5 5600X3D - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  LG 34" 3440x1440
Plex: AMD Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red NAS 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201
OnePlus Ecosystem:
Other Interesting Tech:
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753402
I'd rather use air over worrying about leaks or a dead/worn out pump lol
The worst that could happen to a tower cooler is a dead fan. Cheap to replace.
https://linustechtips.com/topic/1615860-120mm-aio-or-air/#findComment-16753559
