Unmanaged Switch connected to Pro XG 10 PoE Switch
Go to solution Solved by johnt,
Yeah you just need to tag the port on the Pro XG to the camera vlan, and then the unmanaged switch will all get IP addresses on that subnet. So it will be a camera vlan only switch.
Hi all! I'm planning to buy a Pro XG 10 PoE Switch alongside a Cloud Gateway Fiber.
I was thinking about connecting a little unmanaged PoE switch to the Pro XG, and connect 4 IP PoE Camera to the unmanaged one.
Since the cameras will have their dedicated Vlan, is my plan ok?
