New to Audio Gear – Got ATH-R70x for $70, Need Help with AMP/DAC Setup
1 hour ago, GoldenSound said:Honestly, it really would not make sense to spend much money on a DAC/Amp here.
Get the Fiio KA11 as that will have far more power than they need, it's great, and it's about $20. Don't spend any more than that. Any further funds would be MUCH better spent on a headphone upgrade
(Note: Apple USB C to 3.5mm adapter is also fine, but they break easily, are volume limited on android devices and in the EU, and the KA11 is more powerful and objectively a fair bit better for $10 extra plus far more durable)
1 hour ago, saintlouisbagels said:Buy the $9 Apple USB-C to 3.5mm headphone adapter. It is a known good DAC with good output strength.
I use them for all of my headphones $10-$300.
If it sounds no different from your motherboard, then your motherboard is good enough.
Do not bother reading about amplifiers, DACs, etc. Almost every person does not understand what they're talking about, but they're just parroting other users with absolute confidence.
Thank you. I found a good auction and put a bid on a AUDIENT iD14 MKII for $30 so if I snipe that I guess It's all good, otherwise I will likely just buy one of these cheap dongles suggested here and use that should be good enough for me it seems.
