HDR on 32 inch 4k 165Hz g7 neo Samsung mini led monitor
2 hours ago, SSGSS said:
Is the HDR worth turning on in this monitor? If so what profiles do u guys recommend? Thanks.
Its in my opinion one of the worst mini led hdr display i ever had in terms of brightniss even tho samsung says its 2000 nits rtings shows it only goes up to 797 nits on 2%windows  dropping all the way down to 300 nits on a full screen thats worse then alot of newer oleds and also the reason this Display has no vesa hdr rating i send it back after only 2 days of use so no in my opinion ur better off using sdr with local dimming enabled ( hits the same brightniss as in hdr ) and ur skipping all the issus that come with windows hdr u wont notice a differences on this panel anyway
