So... AKG K361/K371 vs ATH-M40x vs DT770 PRO 35/80 Ohms?
Solved by saintlouisbagels,
I would pick the DT 770 Pro 80 ohm.
Yes, the bass is deep.. but if you're skilled enough to mix audio, then you're skilled enough to EQ your headphones to a flatter sound profile.
Plus, you won't 100% use the headphones for sound editing. They will be fun for everything outside of editing.
hamburgerc00l ·
Posted in Programs, Apps and Websites7 -
Technoprime7 ·
Posted in Peripherals2 -
Nexblitzer ·
cool_cool ·
Posted in CPUs, Motherboards, and Memory2 -
1
1
ThankGodItsFriday ·
Posted in PC Gaming2
play_circle_filled
Latest From Linus Tech Tips:
Google Is Selling Fake Products - WAN Show July 11, 2025
play_circle_filled
Latest From ShortCircuit:
Buying a New One is Stupid - JSAUX ROG Ally Battery & Thermal Upgrade Kit
