Budget (including currency): 1000 ish but will be built slowly
Country: USA Tennessee
Games, programs or workloads that it will be used for: editing- Davinci resolve 4k multiview timelines
I have a very very very unique camper - I built it out as an emergency apocalypse camper basically. (Think prepper kind of).  Has a lot of redundancy built into it, can be run off propane or 12v car battery but actually primarily runs off 48 v. Laaaaarge batteries that I built (half the battery capacity of Tesla model 3) also has a ridiculous amount of solar on the roof- enough to power my high efficiency mini split year round without ever having to turn it off.
use case- (I live near nuclear power plant) the air raid sirens go off and I hitch up in 15 minutes and head out to bug out property that has an old well and I can live there indefinitely. I can even power the well with the camper.
i want to build a custom pc that stays in the camper. I need it to be thin and wall mounted to it doesn’t jostle around when driving. I need recommendations for 4 inch thin case that will wall mount on left hand side of slide (measured with tape measure and have about 4.5-5 inches wide above that black power outlet. I also have 20 inches deep. I would prefer full regular motherboard. Ryzen 9950x and full size gpu. Other pc I built for my house has a rtx 5090 in it, could I fit a gpu that big? Tight squeeze I know. But I am good at custom things. See photos for details- I also wanted to wall mount an articulating 32 inch 4k screen to the other part of the slide area for viewing ease. Then I need a rechargeable mouse and keyboard wireless.
I think a rackmount server case would work for you, since most small PC cases won't fit a GPU. Cool setup by the way!
ps. Or you could do a custom wood workbench (if you have a saw and some handy skills) for motherboard then for GPu do a PCIE riser
2 hours ago, jaslion said:
Honestly in this setup a laptop makes the most sense due to campers being a more transient space.
That and desktops dont like a lot of movement and can easily break
Unless I purchase a 4000-5000 laptop, it’s not going to have the capability for video editing
1500 is plenty as you can easily get a high end cpu thats at leaat 7900x level
