5080 Temp limit not showing anywhere
Go to solution Solved by Hinjima,
24 minutes ago, NotIPlayForFun said:
I just installed my 5080 and reinstalled windows a few days ago.
-In MSI Afterburner, the TEMP LIMIT slider is greyed out.
-And, in GPU-Z, under Advanced>NVIDIA BIOS, there is no "Temperature Limit" section
-Nvidia app, under System>Performance>Performance Limits, doesnt show a temp limit either.
Anyone have any idea why this may be the case? Thanks 馃檪
I have the drivers for chipset from mobo, latest gpu (576.80), etc.
Components:
7800x3d
5080
gigabyte aorus elite ax rev 1.2 with latest bios
Are you using聽MSI Afterburner 4.6.6 Beta 5?
This adds support for RTX 5000 cards.
https://www.guru3d.com/download/msi-afterburner-beta-download/
Nvidia also removed the HotSpot sensor from RTX 5000 GPU's.
Components:
7800x3d
5080
https://linustechtips.com/topic/1615595-5080-temp-limit-not-showing-anywhere/
Components:
7800x3d
5080
Yes, I'm using 4.6.6 beta 5.
I actually think this may just be a 5080 thing... I previously thought that I remembered other people having the temp limit option, but I checked again and in OC videos like jayztwocents'聽
(f.e. at 16:59) it actually looks like it's greyed out there too... I guess I misremembered!
Thanks anyway聽馃槃
Thanks anyway聽馃槃
That unfortunate.聽 Just checked, the slider is there on my RTX 4080 and works.
I will check again with a 5070/ti tomorrow and give you an update.
Well, looks like it wont affect me too much tho... because the best my card seems to be able to do is +300 core clock (with +100 core voltage 125% power +2000 memory clock) because if it ever goes over roughly 3225 MHz it crashes :((((
such a shame, given that it peaks at like 66 degrees in time spy extreme and doesnt get close to the 450W power limit ...
thinking about getting a new one atp, i have the impression the silicone lottery cant get worse than this on a 5080, apparently possible OC mostly ranges from +300 to +450 馃槃
From what I have seen with the 5080's is that you gotta reduce your overclock on the memory if you want higher core clock.
Almost all 350-370Mhz on the core I have seen has had +500/1200 on the memory and not 2000.
You most likely won't see your 5080 get near 450w as its a 350w card at stock, overclocking is not going to add another 100w to the power draw.
Its up to you if you want to return it or not, I personally would not.聽 There is diminishing returns and being able to add another 50-100Mhz will probably only give you about 1-2 FPS extra, if that.
