I recently built a new computer and paired the above motherboard with the 9800X3D and Corsair Vengeance 64GB (2x32GB) DDR5 DRAM 6000MT/s CL30.
I've been playing around with overclocking but noticed the system refuses to post when the DDR_VDD is above 1.43v.
I heard Buildzoid also reference this issue in one of his videos (@14:10):
I assume this is a known issue considering how old the video is and is there any solutions?
CPU: Intel Core i5-8600K [Delidded | Frequency: 5.1GHz | vCore: 1.45v - Fuck Intel | Cache: 4800MHz | VCCIO: 1.175 | SA: 1.20]
GPU: MSI GTX 1080 Ti ARMOR 11G OC [Core: 2113MHz | Memory: + 1000MHz | Voltage: 1.181v | XOC BIOS]
RAM: TEAM GROUP DARK PRO EDITION [Capacity: 16GB - 8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36]
Motherboard: ASUS PRIME Z370-A
PSU: SeaSonic PRIME Ultra 1000W
Case: Fractal S2 Meshify
CPU Block: EK Velocity | GPU Block: EK-FC1080 GTX Ti TF6 Radiators: x2 HWLabs SR2 360MM  Pump / Res: EK-XRES 140 Revo D5 PWM Fans: x6 Noctua NF-F12
Primary Monitor: Acer Predator XB271HUbmiprz [Refresh Rate: 165Hz | Resolution: 2560 x 1440]
Secondary Monitor: ASUS VG248QE [Refresh Rate: 144Hz | Resolution: 1920 x 1080]
UPS: APC Smart-UPS RT 2000VA [Online | Double-Conversion]
Benchmarks: 3DMark TimeSpy - First [1 out of 8571]
Interesting. Also it wont yield you much since it's a X3D cache CPU. Interestingly I think I have the same issue on my board. I can't go outside of spec. I think I cap out at 1.45. Its a Gigabyte B550 elite V2.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
huh i wonder if this would make the cl26 kits unstable.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
