Finally got my RTX 5090 FE and it is really disappointing in benchmarks (35K in Port Royal). I know Splave made a video with LTT how software optimizations, I wanted to know if it exists in written form.
Current rig :
- Fractal Design Torrent
- Ryzen 9950X3D with PBO, boosts up to 5.725GHz
- Thermalright Assassin King SE 120
- Corsair 32 GB (2x16) 6000MT/S, CL30
- ASrock X870E Nova Wifi
- SN770 2TB * 2
- RTX 5090 FE
- Fractal Design Ion+ 2 Platinum 860W
Current rig :
- SN770 2TB * 2
- RTX 5090 FE
If you're using Edge, I suppose you could use Copilot to summarize the video if the video has captions. 🙂
Is it all stock? Just default setting and hitting run in the benchmark? A stock FE (the hottest running model) and the overclocked to within an inch of its life chilled water cooled Astral is going to perform vastly different. Are you expectations set correctly? 3DMarks leaderboards are going to be dominated by heavily overclocked results.
I'm not sure this was an ideal pairing, TBH.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
18 minutes ago, Hinjima said:
Im just curious about the video, do you have a link?
and they just did a new one with water-cooling
Current rig :
- SN770 2TB * 2
- RTX 5090 FE
You want GPU overclocking, not PC optimization.
Various guides show how to tweak a 5090.  You need MUCH better cooling to get a noticeable improvement.
You may be running into power issues too, so be aware when you change things.
Raven: AMD Ryzen 5 5600X3D - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Interesting Tech:
So the FE is shite in terms of cooling ?
No, they're all shit for cooling.  You can only cool 600w+ so well, with 3 fans.  You simply cannot dissipate that much heat from such a small area well enough, the cards perform as they perform.
Get a liquid cooled model, or build a custom loop, if you want to bump a level of performance.
Your PSU may be light too, 860w isn't giving the 5090 a lot of room to push itself.  Especially when they can use 600w+ alone.
OnePlus Ecosystem:
Im with @GuiltySpark_ on this one...this surely cant work well
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3)
Plus a 200+(?)W CPU, youve minimal headroom to run...everything else...if those are both running full tilt
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
I dont know I see 55 - 60 degrees while gaming so ...
Indeed but who is running CB23 and Kombustor at the same time ?
Would like to see temps, clockspeeds and power usage under an OCCT or Cinebench all-core test for 5+ minutes. A little single tower is really pushing it for a 200W+ CPU.
