Hello,
I have tried troubleshooting this problem using the forum posts here but no luck so far. My MB, an Aorus B850i pro with a AMD 9700x doesn't want to start. When I plug in the powersupply the CPU led blinks twice and the CPU fan spins very briefly. After that nothing when I push the power button or use a screwdriver to short the PW pins on the FS header. All the components are new so I'm afraid something is DOA but I don't have any replacement part here to troubleshoot the problem any further. I did do the bios Q flash but nothing changed after that.
Any tips on what it could be are very welcome.
5 hours ago, Maarten100 said:
Hello,
Check the CPU 8-pin connector on the top-left of the motherboard.
Check the fan cable/header for the CPU cooler.
What GPU are you using?
I don't recall, but I believe for my Gigabyte X870E Aorus Pro Ice motherboard, the iGPU was not enabled by default - if you are using the iGPU at the moment.
Ryzen 9700X should be supported out-of-the-box.
Which version BIOS did you try to flash, using the USB Q-Flash Plus feature?
When you say the CPU LED blinks twice, are you talking about the Debug LEDs on the top-left corner of the board?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
