Hello, for the last 2 years I had this cpu perfectly fine and I bought a new cpu, my friend wanted it so I pulled it out and after he looked it at it he said 'there are some bent pins'. I was wondering if this bent cpu pin is fine and is it fixable? I really want to give it to my friend
He said this could be a factory defect and I should contact customer support and press my rights as a valued customer
https://linustechtips.com/topic/1615391-slightly-bent-cpu-pin/
<-- Thread Locked -->
No Trolling or Shit Posting.
"Black Out"
Dedicated Streaming Rig
https://linustechtips.com/topic/1615391-slightly-bent-cpu-pin/#findComment-16750507
Guest
