So I built the system up but the VGA diagnostic led is coming on. The GPU is brand new and so is the motherboard. I try my old GPU which I have verified works  on my 1500x system. But again VGA diagnostic led.
I try the new GPU in my old system which unfortunately doesn't have diagnostic LEDs but I don't get any output. Try my old GPU it works like a champ.
Am not sure if the 7700 has onboard graphics but that doesn't give me any output and the VGA diagnostic led is still on
So I have a dead move and GPU? wtf. I must enter the lottery this weekend.
you can try RMAing your gpu and motherboard. its bad luck if they are both dead on arrival
It does. The 7700 should give a picture if you plug a display cable into the motherboard, though for testing purposes that would be best without a potentially faulty graphics card in the primary slot.
What is the old system motherboard? Some of these newer cards don't work very well in old(er) PCs.
