Too many SATA powerr connections! Need help.
Go to solution Solved by jaslion,
You can buy a sata header splitter and connect it to the ssd chain. Those use less power than the fans
I recently upgraded my PC, however I don't seem to have enough SATA power connections for my fans. I'm looking for suggestions to solve this problem.
Components:
Motherboard - Gigabyte B850 GAMING X WIFI6E
PSU - ASUS ROG Strix 1200w Platinum 80
Case - Phanteks NV7 D-RGB
CPU Cooler - Arctic Liquid Freezer III ARGB 360mm
Current Case Fans - 3x Arctic Fans
Case fans I want to upgrade to - 8 x LIAN LI SL-INF 120
Current Setup:
The PSU supports 2 SATA power cables, with each cable having 3 SATA power connectors, for a total of 6 power connectors.
The case controller uses 2 SATA power connections (Channel A and Channel B), my 3 SSDs use a connector each, for a total of  5/6 SATA connectors in use.
I have the default fans that came with the CPU cooler block connected to the motherboard's cpu fan slot. And the 3 arctic case fans connected individually to the motherboard's system slots.
The setup I want:
Leave CPU fans as are. Remove the 3 arctic case fans and replace them with 8 LIAN LI Fans (2 blocks of 3 fans and 1 block of 2fans).
The problem:
The LIAN LI fans make use of a fan controller that uses 2 SATA power connectors. I'm already using 5 out 6 of my SATA power connectors from my PSU.
https://linustechtips.com/topic/1615332-too-many-sata-powerr-connections-need-help/
