hiya friends i’m looking at ASUS Vivobook 15.6” laptops now, can’t decide which to pick
AMD model has 5825U CPU and Intel model has 1335U CPU
afaik nowadays AMD is in the lead regarding both desktop and mobile CPUs and this choice seems obvious to me. Not sure about Intel’s P and E cores thing, looked it up and it says 10 cores / 12 threads vs AMD’s 8 cores / 16 threads
Intel model is slightly (negligibly) more expensive
Both models have 16gb ram and 512gb ssd
https://linustechtips.com/topic/1615229-pls-help-me-choose-my-laptop/
The advantage of Zen-based chips is, on average, SLIGHTLY better battery life, somewhat better and more predictable performance. However, the intel chip does offer better GPU performance, so that is something to take note of
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
thanks
not sure if i care about GPU performance at all
i mean both GPUs are really bad haha, its not like this laptop can run any somewhat recent videogame
3 minutes ago, triumph of steel said:
thanks
No worries!
Honestly, the two are fairly similar, I would personally go with the Zen option, but for most of the time, they would perform about the same. So, I don't think you will go wrong either way tbh
Intel's U class chips all have just two P-cores along with 8 E-cores. The two P-cores are hyperthreaded and the 8 E-cores aren't hyperthreaded, therefore you have a 10-core CPU with 12 threads
