Question about 90 degree 12VHPWR cables - Seasonic
Go to solution Solved by Spotty,
Cablemod recalled their 90 degree angled adapter connectors. You can read more information on their recall page: https://cablemod.com/adapterrecall/
Supposedly the 90 degree full cables did not have the same issues as the 90 degree adapter connectors. The full cables should be safe to use. The cable you linked (RT-Series) is the correct cable for your Seasonic power supply.
If you're buying the cablemod angled cable pay attention to the A / B variants, that dictates whether the cable will bend up from the connector or downwards. With your card if you want the cable to go down you will need the A variant.
I have an "issue" where I want to install my 12VHPWR cable from a Seasonic Prime TX PSU to a 5080 Astral, but it won't really fit nicely without bending the cable really hard, which I've heard one shouldn't do with these cables, as such I'm looking to get a 90 degree adapter, but those seems prone to melting? Please correct me if I'm wrong here.
So I'm wondering if a full length cable from say CableMods is a safer option? Like this one: CableMod RT-Series Pro ModMesh Sleeved 12VHPWR 90 Degree
Just so I don't ruin my card 😄
Thanks!
Whatever you do, make absolutely sure that you have fully inserted the cable. Visually check it from as many angles as you can.
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
which is a pretty useless exercise when the latch on these cables is so weak it'll come undone just from the weight of the cable.
my 4070 isnt "squeezed in" by any means, yet after test-fitting the sidepanel i found that the <absolutely certainly> latched connector had come undone.
Yikes, I'm kinda glad that I'm yet to put a 40 or 50 class card in a case that tight...
Useful Websites:
Bio:
Fun Facts
