Is Telus pure fibre worth it?
Go to solution Solved by Lurick,
40 minutes ago, the real sfpour said:
so I should get fibre?
Yes, easily
6 minutes ago, the real sfpour said:
I'm thinking of changing to Telus pure fibre gigabit internet from Shaw 5G should I do it or is it not worth it, the 5G costs more than the gigabit.
Well it is cheaper, so on the face if it, yes, it is worth it. Need more details to give a better answer.
9 hours ago, the real sfpour said:
Like what are the benefits of pure fibre and what about the speed difference does that make a actual difference for high speed gaming like COD?
Lower latency and better reliability for one
Speeds are going to be more consistent as well
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
