Hey everyone,
So I’ve got a Gigabyte RTX 3090 that I've been using since launch. Recently, I noticed the hotspot temps were getting dangerously high (~102°C) while gaming and even spiking during something as simple as watching YouTube videos in fullscreen. I decided to repaste the GPU, which brought the hotspot temps down to a much safer ~70°C under load now – so that part seems resolved.
However, I’ve been monitoring the VRAM (Memory Junction) temps using HWInfo64, and they still regularly hit 100°C during heavier games like MH wilds. For lighter games like Dota 2, the VRAM temps stay in the 70-80°C range, which seems fine.
I had the GPU repasted by a mechanic, and he checked the pads, saying they were in good condition . I even checked them myself – no visible damage or drying out. But I’ve heard that even decent-looking stock pads on 3090s can just lack the thermal conductivity needed for these heat-heavy cards.
The card hasn't crashed yet post-repaste, but I did experience a black screen once (screen went dark, fans ramped up to 100%, but audio continued). Not sure if that’s directly related.
Basically im asking is should i change the Pads or its okay ?
And if so what would you recommened ?
The 3090s have split chips, meaning chips on both sides. Usually the hot ones are the ones on the back side of the board cooled through the backplate. I have a 3090 FE and I have it under a full water block for both sides to keep them cool. For Air cooled, its usually a good idea to make sure you have a fan directly pointed on them or at them to move that hot air away to exhaust it quickly.
"Black Out"
Dedicated Streaming Rig
my case is such that i cant have a fan directly pointed at them , though there is one at the bottom blowing in air to the GPU , nothing on the top side
Posted (edited)
I know people overclock their VRam so probably you could underclock yours. Probably without much downsides.
Just an idea.
Edited by leclod
If you don't answer to us, we won't get notified.
Just an idea.
by how much and how big will be the temp change ?
Posted (edited)
I'd just try it (-100MHz), nothing to lose.
(undervolting might help too and that's free)
Edited by leclod
