Budget (including currency): $250 USD
Country: USA
Games, programs or workloads that it will be used for:
  • Base OS: unRAID
  • VMs: 1 (2CPU/4G today) that handles nginx reverse proxy / fail2ban / offsite backups, 1 (2CPU/2G today) that handles home automation (Home Assistant)
  • Dockers: MariaDB, ChannelsDVR, Emby (guest access to family photos and videos), Plex (personal access to media on site and remotely--probably max 1 transcoding stream at a time), freshrss, Wordpress
I currently run two servers in a active / standby configuration. They both have Xeon E3-1240v2 CPUs with 32G of RAM and a Seasonic SS-430GM PSU. I recently bought 2 10G SFP+ PCIe 2.0 x4 network cards. While the motherboards use the same C204 chipset, they are slightly different models and in one the 10G card is not recognized. I found a "like new" version of the motherboard that works with the 10G card, and after examining it, it looked like it had never been used. Unfortunately, a little after I installed it and turned on the system, a small fire started around a couple traces on the MB! (All the fans came on, but it never posted, with the fire starting after about 30 seconds.)
The configuration I have now works for what I do and uses around 130W on average per server, (although the backup server only powers on a couple hours a day to synchronize with the primary one and the remote backup site). However, I figure for better hardware support (and available options) I should modernize things somewhat. I'm looking for something that can:
  1. At least match my current CPU in performance
  2. Consume the least amount of power as possible
  3. Use a platform that currently has readily available options in case I need to swap anything out
  4. Support 8 SATAII/III drives on-board or with a PCIe expansion card (currently I have 2 SSDs as unRAID cache drives, 4 HDDs for parity / storage, 2 empty HDD slots for future expansion, and one PCIe SATAIII card with 2 ports as the replaced MB only came with 6 SATA ports on board)
  5. Have enough PCIe slots for at least the 10G NIC and (most likely) a SATA card, plus additional lanes for maybe a video or other card for transcoding and/or AI-type things (I would like to move all the home automation voice interaction in-house at some point instead of using Echo devices)
  6. Support at least 32G RAM
Basically, I figure I need to change the MB, CPU, and RAM. Plus a CPU cooler if the CPU does not come with one. The rest of the parts I can re-use from the existing system. Looking around at similar posts, the AMD 5600G and Intel i3-1x100 CPUs seem to be recommended for low-power NAS usage. But when pricing parts, they both land around $320USD (example AMD build: https://pcpartpicker.com/user/KFStein/saved/#view=dV4c4D). I looked around for some mobile CPU options, but the motherboards I found were all small form-factor with usually a max of 6 SATA ports and 1 PCIe slot. Any other suggestions are welcome!
https://linustechtips.com/topic/1615105-low-power-nas-upgrade/
