7 minutes ago, Nooblite said:
Can anyone recommend a good cpu+motherboard+ram bundle? Max budget is $610, not sure if I should get a 7600x or 7700x, and which motherboard.
https://www.memoryexpress.com/Search/Products?Search=processor bundle&Sort=Price
Are you gaming or doing other workloads?
What do you do on your computer? Then it depends on how much RAM and how many cores you will need.
I am gaming, maybe some office work with word and light excel. Ideally 32gb of ddr5 ram, not sure which cpu or motherboard to get. Apparently some are better than others, but the prices all look the same.
Gotcha!
Then I would recommend the 7600x or 9600x!  6 cores and 12 threads are plenty even for modern games.
Do you need WIFI?
Yes
https://www.memoryexpress.com/Products/BDL_MM00004810
This is a good budget option that will work really well.  I personally don't like very 'cheap' motherboards as they do lack some features. Had a lot of people wanting to swap motherboards because they bought a super cheap one and realized it lacked what they needed or wanted, like more FAN connectors for example.
This is also not a full sized ATX motherboard.
https://www.memoryexpress.com/Products/BDL_MM00004639
This one I do like.  It does have WIFI.
It will also handle a faster CPU like a 9800X3D or a 10800X3D whenever AMD releases that.
So you have a good upgrade path.
What a breath of fresh air. Finally.
Thank you.
AMD R9 9900X | Thermalright FW PRO, 3x TL-H12-X28-S, 3x TL-P12
Asus Strix X670E-F | 32GB Lexar Ares @ 6400 30-36-36-68 1.55v
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770, 5TB
Asus PA602, 2x 200x38, 1x 140x28, TL-B8, TL-P9 | Vertex GX-1000
Is this a full build or just cpu board and ram upgrade?
What games?
And is this canada or us?
https://pcpartpicker.com/list/BhYGwY
610$ is more than enough to get you a 7800x3d and 32gb of ram if you are in the us
