I've had an AIO cooler for quite some time now but I don't think I have it properly set up to get the cooling I want. I'm using a Thermalright Frozen Notte 240 on an i7 13700KF on a MSI Z790-P Pro WIFI. On the AIO, there's a cable that has 3 contacts and the two fans are both 4 contacts. I have no idea of how to properly set this up in the BIOS and it seems to not be doing a whole lot because on idle I'm getting high temps. Thanks.
https://linustechtips.com/topic/1614959-how-do-i-properly-set-up-an-aio-cooler/
Can you send photos of how you have it set up?
Umm, I just install them and watch them go.
I don't BIOS anything.
What temps are you getting?
Sage: Ryzen 7 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Raven: AMD Ryzen 5 5600X3D - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  LG 34" 3440x1440
Plex: AMD Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red NAS 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201
OnePlus Ecosystem:
Other Interesting Tech:
Everything is default but System 1 and System 5 are both running at PWM because they run at full speed when left on DC. With these settings, I'm getting around 60-70 Celsius with DLSS Transformer Balanced with FG and high settings at 1440p on Cyberpunk 2077.
image.thumb.jpeg.0e29eb1ea3e9114597a11175947fbebf.jpegimage.thumb.jpeg.7edc0596495c3c1077f485b8dedecead.jpegimage.thumb.jpeg.e226f19cf3fa2ab2958266878cee1af8.jpegimage.thumb.jpeg.0d2a88ef8cbc2597190a5196d77d3aa2.jpegimage.thumb.jpeg.414a8ce76ccb6af18f6172f0058d4317.jpegimage.thumb.jpeg.c4a3b527f9b1f63b5551830742734973.jpeg
So it's at PWM and running 60-70c in Cyberpunk?
What's the issue?
OnePlus Ecosystem:
Just now, Dekuuz said:
I just thought that an AIO would at least run a bit cooler than a tower cooler?
Not the one you have, no.  240's are basically the same as a good tower cooler, you need a 360 to beat one.
60-70c is quite cool for a 13700K though, so you're actually doing well.
Find comparisons for more info.  Don't just assume anything.
OnePlus Ecosystem:
Ah makes sense... Thanks!!
