i am building my first AM5 pc and am getting no post.
specs are:
b850m gaming x wifi6e
9800x3d
5070
64gb 6000mt/s cl30
lian li sp850 sfx psu
i have cleared cmos reseated all components and cable ran with 1 stick of ram and flashed bios and im still getting no post
any help would be amazing
https://linustechtips.com/topic/1614948-red-light-on-mobo-labelled-cpu-and-no-post/
specs are:
9800x3d
5070
64gb 6000mt/s cl30
How long you waited ? first time post may take quite long on AM5.
Is  the RAM dual stick? or quad stick ?
Refresh before you reply
3 minutes ago, enophonyx said:
its dual stick, 2x32gb corsair vengeance. ive waited upwards of 5 minutes for the post
Any kind of sign on the motherboard ? like debug led, etc.
Tried plugging display cable to motherboard instead of GPU ?
GPU currently isnt plugged in to focus more on the mobo, got a display port connected to the mobo. only LED is a CPU LED
Your motherboard manual seem to insinuate that that is a sign of a problem related to CPU.
I'd check the pins on the motherboard at least.
forgot to follow up here, after testing everything i could think of, i took it to a local shop for a diagnosis and the mobo was broken so i have sent it back for a replacement. thank you for your help!
