Evening all!
It's been a little while since I put a build together. 2024 was full of ups and downs, mainly downs regarding family, sadly. TLDR is that my mum died, dad had a stroke, and my wife had an op, all within around 9 weeks, so I had a load to deal with and couldn't really be modding with work and everything else that was going on.
Now though, we have moved on, and it's time to get back to something fun, so, let me introduce you to the Porsche Motorsport themed build!
The vibe on this will be in tune with my previous Valentino Rossi Yamaha-based Antec Torque, one of my favourite builds. For this, we will be going with a be quiet! Light Base 900, with a host of other goodies from my friends at be quiet!.
Some parts just dropped in today, I am still waiting for the case to arrive before I start uploading pics and detailing what will be happening on this one.
For now, just know I'm back, and this should hopefully turn out really pretty!
@Cre8Modding
Reviewer @TweakTown
Former Writer @Maximum PC
Former Reviewer / Modder @KitGuru
https://linustechtips.com/topic/1614920-porsche-motorsport-light-base-900-build/
So I am still waiting on the case, so I might as well crack on with the build log.
First up, we had a parcel from be quiet!, this is the power supply and some case fans. The dog thought it was something for her, so naturally she was disappointed it wasn't full of treats!
The power supply we will be using is the be quiet! Dark Power 13, 1000W. This will be more than enough juice for this build, and be quiet! are renowned for making high-quality power supplies among other things.
We also have 2 packs of be quiet! 120mm Light Wings PWM fans. These triple packs include hubs, but the Light Base 900 also comes with one so we shouldn't be needed these. be quiet! have also sent some reverse Light Wings, but 140mm by mistake, so once that's rectified we will get some unboxed images on to the thread.
So we are still waiting on the delivery guy for the case. The plan is to get all the case mods done before I throw in some hardware. I'm keen to see just how easy the Light Base 900 is to strip down for what I have in mind for this build.
@Cre8Modding
Reviewer @TweakTown
Well, the case has landed!
I'm busy on reviews tomorrow and Friday, then away for the weekend at Soccer Aid, so I will get an update sorted early next week!
This thing is huge btw, such a great looking case!
@Cre8Modding
Reviewer @TweakTown
Post everything you can about the PSU. It was between this and Antec but went with Antec in the end and cable quality was some of the best I've seen. Wondering what my alternative PSU cables would have been like.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec 1000W 80+ Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64- Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
I've used be quiet PSUs for years, I have done loads of mods with them, and the quality has always been up there, even their "budget end" units. The Dark Power Pro 12 came with great braided cables.  I think BQ do need to start looking at aftermarket cable sets in a variety of colours too.
@Cre8Modding
Reviewer @TweakTown
I can't wait until your build is done! I love Porsche cars!
So the be quiet! Light Base 900 has arrived, and boy, is it big!
First, the box seems to have got into a fight on the way here, but the contents are all ok!
be-quiet-Light-Base-900-FX-Box-Side-1.jp
be-quiet-Light-Base-900-FX-Box-Side-2.jp
When the packaging is removed, you get to see this amazing-looking case in all its glory, and it already has me thinking of what I want to do with the cooling runs in this one, theres loads of room to play with.
be-quiet-Light-Base-900-FX-Front-Angle.j
I know there are 3 ways to have this case sat on a desk, but I think I will stick with the traditional layout.
be-quiet-Light-Base-900-FX-Front-Square.
be-quiet-Light-Base-900-FX-Top-Filter-Re
The GPU sag bracket and the folding 2.5 drive caddy to the rear are nice to have too.
be-quiet-Light-Base-900-FX-Bottom-Fan-Mo
be-quiet-Light-Base-900-FX-GPU-Back-Expo
be-quiet-Light-Base-900-FX-GPU-Bracket.j
be-quiet-Light-Base-900-FX-Internal-Top.
So that's the Light Base 900, now we need to turn it into a Porsche edition!
Il cover fans and power supply next, I'm waiting to hear on a few things still, so progress may be a bit slow over the next couple of weeks.
@Cre8Modding
Reviewer @TweakTown
  • 2 weeks later...
So let's take a closer look at the PSU and the fans!
I've gone with the Dark Power 13 1000W, simply because I was advised that the Pro version won't fit in the Light Base 900. This seems a bit daft, one of their premier cases not being able to hold their high-end PSU, but it's fine, and the Dark Power 13 will be more than enough, the Pro version just adds that extra little wow factor!
Dark-Power-13-1000-W-Open-Box-INternal.j
Moving onto the fans, the Light Wings 120mm 3 in one pack also includes an ARGB hub, I do wish this included fan connectors also, rather than having to use 2 different connection points. I think it would just make sense to pack it all into 1 unit for convenience. Having said that, the Light Base 900 will take care of all this with the included hubs, so we won't need the ARGB hub anyway.
Light-Wings-120mm-3-Pack-PWM-Contents.jp
Light-Wings-120mm-3-Pack-PWM-120mm-Fan.j
Light-Wings-120mm-3-Pack-PWM-120mm-Fan-R
Light-Wings-120mm-3-Pack-PWM-120mm-Fan-S
Light-Wings-120mm-3-Pack-PWM-ARGB-Hub.jp
Light-Wings-120mm-3-Pack-PWM-ARGB-Hub-Ca
The next job to sort is the motherboard. I reached out to ASUS UIK to try and source a Z790 Formula. I think this would have been perfect for the build, but sadly they dont have one available. I'm still waiting to hear from a few other contacts, but if I can't get one, I may switch platforms to the Z890 series and opt for the Gigabyte Aorus Pro Ice. In my time modding and building, funnily enough, I have never used a Gigabyte board, so it might just be that this is the way to go. I still wish it could be the Formula, though!
@Cre8Modding
Reviewer @TweakTown
1 hour ago, Cre8 Modding said:
So let's take a closer look at the PSU and the fans. I asked be quiet! to send some 120mm Light Wings, plus some of them with the reverse blades. For some reason, they sent 140s reverse, so I am waiting for the reverse 120s to turn up.
It looks great!
  • 2 weeks later...
Ok then, here we go!
One of the first things you can do when building a race car is to make it lighter, so that's exactly what I've been doing with the Light Base 900. This should add around 10mph to the build!
Joking aside, this case is well-built. It has taken me around an hour to strip it down, being careful not to break anything and ensuring I removed all the wiring cleanly without damaging or snagging anything.
The mountain of parts removed is insane, and I will be modding some of these too.
For the original silver trim, I think this will be vinyl-wrapped with a backlit Porsche logo at the top. It's a shame that the silver part is plastic-welded to the bottom, as that would have made it easier to do what I need to with them.
The next step will be to remove the motherboard tray so it can undergo a paint job. I will let you guess what color it's going to be! I also need to place my Alphacool order. I wanted to use three 120mm X-Flow radiators at the bottom, but I think it will be a close fit to the front glass, so I might opt for 360mm radiators instead. I'm still undecided on a 420 or 360 distro too; it doesn't appear that Alphacool has listed a RH 420 yet, unless I'm mistaken.
So that's it for now, can't wait to get the tray back from paint and see how it looks in this.
@Cre8Modding
Reviewer @TweakTown
I can't wait!
Another quick update!
The motherboard tray and panels are out, ready for paint. I'm not sure how long it will take, as the powder coaters I use are generally really busy, so it may be a week or so before they are ready.
Excited to see these in their new coat!
@Cre8Modding
Reviewer @TweakTown
