Help with PC turning on but not booting
Solved by Livin,
1 minute ago, Zernell said:It's really hard to see as they're extremely small. But as far as I can tell, no, none of them are lighting up when I turn the system on.
If none of them are turning on at all I would lean towards it being either power supply or the board itself being problematic. If you are also having some fans that are plugged in to the board that are not starting with the rest of the system that doesn't bode well for the board's functionality.
If you have a known good power supply that you can plug in (even if it's something smaller, just to see if you can get a POST), that would be my next move. Should the board do the same thing with a known good power supply I'd say you have a bad board.
