Quality on different optical outputs
Go to solution Solved by AbydosOne,
5 minutes ago, danalog said:
Theoretically it should be lossless and theoretically there shouldn't be interference on digital audio, but I want to be 100% sure that a crappier soundcard won't actually affect ability to make a bit-perfect digital copy.
Assuming the interfaces/drivers aren't doing any processing to the audio, I would expect them all to be bit-perfect.
Because of the ways that Windows handles audio, I'd be suspicious of expecting it to be perfect as compared to the original file, though...
This is a really dumb question but I want to verify that quality will be identical across any sound card with SPDIF/digital output? Of course some are capable of higher bitrates but what I mean is, will the quality on a $250 Sound Blaster card be the same as the onboard audio of a 2006 Dell Studio PC if they're both set to 16 bit 48khz? Theoretically it should be lossless and theoretically there shouldn't be interference on digital audio, but I want to be 100% sure that a crappier soundcard won't actually affect ability to make a bit-perfect digital copy.
Thanks!
https://linustechtips.com/topic/1612911-quality-on-different-optical-outputs/
digital output is digital output, it's ones and zeroes. in the same way that every flash drive you use to transfer an MP3 file will make the same resulting file on your USB-enabled radio (anyone remember those?)
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Silicom (Intel) X540-AT2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K12 Blue (RGB backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (Aquantia AQC107) 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ═╦════ Flex 2.5-8 ═╦════ Flex XG ═╦═ Veda
                           La Vie en Rose ═╣ La Vie en Rose ═╬═ Doven Wolf  ╠═ Veda-NAS
                                     Veda ─╜      Narrative ═╝              ╟─ Switch 8-60W ─┬─ Veda
╔═══════════════════════════════════════════════════════════════════════════╝                └─ Veda (IPMI)
║    ┌ Closet ┐     ┌───────── Bedroom ─────────┐
╚════ Flex XG ═╦╤═══ Flex XG ═╤╦═ Byarlant
        (PoE)  ║│             │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐ │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘ └── Work Laptop
     Bedroom ══╝│
        Jack #2 │        ┌──────── Media Center ───────────────────────────┐
                └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Thanks!
To your ears or to measuring equipment? Different dacs have different characteristics. They "sound" different. Can you hear it? Probably not. Can it be measured? Yep.
Sorry, jumped the gun, this would be pre-dac.
