I gave up
I had tdp current limit set to mb values and tried i think intel + unlimited
2 cables instead of one for the cpu power
I set limit (pl) to 200 and 250 watt, i had default values on
I even tried power saving in throttlestop but that limited the cores to mid 20's instead of 45 on all cores
virtual core error using occt
my 13400f is the same cpu just lower mhz but despite that i got errors, a not 100% stable 12600kf (an unlocked copu with m ore single core performance)
had iccmax on max
i tried power limit to 4
My 12600kf also had error on the virtual cores in occt
I don't get it just 4.9ghz max instead of 4.6ghz and it should have a little extra singel core perfomance, just wasn't stable, corsair rm850x psu, temps can get alot higher on a 12600kf but stille not super crazy high like a i7 12700k(f) or i9 12900k(f)
If Ring Down Bin is enabled, the P Cache will always run slower than the Core. Usually 300 MHz to 600 MHz slower depending on the CPU model. This improves stability.
