im looking at how much it would be to do a custom loop water cooled system only my cpu no gpu, but I'm not sure where to start with brands and such, im looking to water cool my 5800x3d in a lian li O11 air mini and i have a full atx mobo, my miother board is the b550 ASrock phantom gamin velocita.
https://linustechtips.com/topic/1612774-1st-time-water-cooling-shopping-list/
Is this just for fun and you want to learn how to do it?
Or do you think you need a custom loop for the 5800X3D?
id like to lean my cooling at the moment is plenty enough with my noctua NH-D15, but i like the aesthetics and to learn how becasue id like my next full system rebuild to be hardlined water cooled.
You really don't need a custom loop for a 5800x3D, and anyway it doesn't make much sense to do a loop only for the CPU
But it can be for fun or the looks
Do you have a budget ? Things really add up fast for custom watercooling !
Hi buddy,
As @PDifolco and @Hinjima have said, these days, neither a CPU or GPU really require any water cooling.
If however (like me) you just want to do it for fun / aesthetics / challenge then crack on, its great fun if not ruinously expensive.
A few things to consider:
1. What is the o11 Air Mini like for water cooling? How many Rads can it support simultaneously? Can these rads be thick-boys or do they need to be slimline?
2. Do you want to start with soft-tubing or do you want to go balls-deep and go straight into hardline loops? Soft is easier to work with and maybe a better launching platform BUT hardline looks better (imho) and I would argue its better for smaller / tight spaces given the fact that soft-tubing kinks with tight bends.
3. Brands!!! EKWB - Bykski - Alphacool - BarrowCH - Corsair - Heatkiller are all good options. Barrow would be the budget option with the others being more premium. EKWB are in a bit of a dark spot right now so have supply issues across the globe but they have a very slick product range including blocks, pumps, rads and fittings.
Keep us posted.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 3080ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 2080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Kitchen PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 1080ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
39 minutes ago, gergory117 said:
id prefer to keep the price of the components down to at least below 500 or 600 USD
In my (somewhat limited) experience, getting into watercooling is gonna be close to a grand.
26 minutes ago, gergory117 said:
so looking into it biggest radiator i can fit are 280mm on the front and a 240mm on the bottom and side, id prefer to keep the price of the components down to at least below 500 or 600 USD. and i do have mirco centers near me.
500 to 600 should be doable. Not sure about $$ but here in the UK, that would buy a pretty good cpu block, a couple of rads, pump / res and still leave enough for fittings and pipes but as others have said, its a pretty expensive hobby and if you get the bug, will cost you plenty as you try and water cool everything.
When it comes to rad compatibility, be careful with rad thickness, especially when fitting multiple rads.
A great example of a mm here or there causing clearance issues would be EKs coolstream vs their quantum surface. Both ranges come in 120/140 , 240/280, 360/420 BUT the Quantum Surface rads are a couple of mm larger in all dimensions that can be the difference between fits like a glove, snug as a rug or total misery!
Another thing to consider, and maybe a good option for a first time loop would be to look at a distro-plate. Their availability is dependant on the case BUT if one is available for the o11 mini air then they can make running a hardline loop much easier as when placed correctly, make all flow and return ports line up perfectly and usually only a single 90 degree bend required per run. EK do some great distro plates but other brands might also offer for slightly less ££ $$.
Once you get more proficient then replacing the plate with a more traditional pump / res combo can open up for more interesting loops but will almost certainly require more complex bends.
i already have loads of fans sitting around so those arent an issue, would soft line or flexible line be cheaper (tho id prefer trying hardline), would 2nd hand or used radiators and water block be trustworthy? because that could help lower costs, especially with still being on AM4 id expect used blocks to be available in decent number and prices.
I would say, the price difference between hard and soft tubing is marginal as you still need the bulk of the fittings for both options.
Used Rads are an option. I've bought my fair share on eBay and never had any issues although there's always the risk....
A good thing to have in your water cooling box of goodies is a cleaner solution from the likes of Mayhems Blitz. They have a cleaning solution that's designed for rads specifically and another for tubes, fittings and the rest.
Used blocks for CPUs and GPUs can also be a good option but again, your milage may vary. Taking them apart and giving them a good scrub to clear out any gunk is actually quite easy and most manufactures factor in this kind of annual maintenance into their designs.
The only thing I would say might be an issue with used would be the pump or res / pump combo unit. These are always best to buy new given the consequences of a pump dying.
Ok, maybe you might need to factor in the tools required to cut and bend the hardline but in the long run, that's usually a one-time purchase.
And if this your firsts hardline build, a load of spare tubing to allow for all the botched attempts and mistakes lol
52 minutes ago, gergory117 said:
yea im not too afraid of buying used so that's what ill probly go for with the block and rad used with a site like JAWA or Ebay and ill check for what my local micro centers have in stock for pump res combos and tubing
Yeah imo you can get away with only 1x 280mm rad, a block and a pump+res, so only 6 fittings and not much tubing needed, a heat gun plus something to cleanly cut hard tube,  overall less than $500
Looks like a good plan.
A couple of other things to consider.
1. While most ancillary fittings like 90s, 45s, Ball Valves and whatnot are all 1/4GN universal, the fittings that go on the end of each length of pipe ARE gauge specific so be wary of that depending on if its 12mm, 14mm or 16mm tubing. I found the 12mm a tad too skinny, the 16 a bit too chunky so settled on 14mm for all my builds.
2. Hard tubing comes in 2 different material types. PETG or PMMA (acrylic). While PETG is easier to work with as it can be cut with a rotary pipe cutter and PMMA requires either a hacksaw or hobby / tabletop circular saw, PMMA / Acrylic bends with a tighter radius so it looks a little cleaner.
