10 minutes ago, pmtic said:
I am new to aio cooling and I don't know if this sound is normal. I've got nzxt kraken 360mm. Thank you in advance 🙂
That almost sound like GPU CoilWhine.
That sound from the AIO is a higher than what I would be comfortable with for 24/7. Not because of anything being wrong but the noise is too loud.
What is the pump speed set to?  There could be some air trapped in the pump as well.
The pump is set to 2300 RPM. The sound might be that loud because I placed my phone's microphone half a centimeter away from the pump. With that in mind, does it sound okay to you?
For that speed, Yeah.
You can try lower the speed to maybe 1700 RPM's to try and lower the noise a little if its bothering you.
But I hear nothing that would cause me to worry.
