Old GPU sag for X870 Tomahawk, Compatibility and RAM ?
Go to solution Solved by RONOTHAN##,
16 minutes ago, PecaCZE said:
I plan to build 9800X3D and X870 Tomahawk, would like to know if my old GPU sag bracket is compatible with new mobo ?
Don't see why it wouldn't be, the motherboards have pretty similar heatsinks so if it fits on one it should fit on the other.
17 minutes ago, PecaCZE said:
Also heard that XMP is just fine with AMD, this RAM should be compatible, right ?
G.Skill Trident Z5 RGB Black, 2x 16GB, 5600 MHz
Yeah, that should be fine.
Hi,
I´ve refunded 13900K which is paired to Z790 Tomahawk Wifi DDR5.
Sorry, I can´t find it but I think that gpu sag was included with Lian Li case, GB-001.
accessories GB-001-anti-sag bracket for graphics cards.
Thank you
Case        - Lian Li O11 Dynamic Evo, black
MOBO     - MSI MAG X870 Tomahawk Wifi
CPU        - AMD Ryzen 7 9800X3D
GPU        - Asus TUF Gaming, RTX 3080 10GB, V2 OC
RAM        - G.Skill Trident Z5 RGB Black, 2x 16GB, 5600 MHz
CPU cooler  - Noctua NH-D15 chromax.black
Storage     - Seagate FireCuda 530 Heatsink, 1TB + 500GB
PSU          - Corsair HX1000
Fan           - Lian Li SL-Infinity 120mm, black 10x
Cable        - Lian Li Strimer Plus V2, 24-pin + dual 8-pin
Display     - Asus ROG Swift PG279QM, 27" 240Hz
Mouse       - Logitech G502 Hero
Mousepad   - Logitech G640
Keyboard    - Logitech G513
Headphones  - Logitech G PRO X
The Lian-Li anti-sag bracket is universal so it should work fine. I've used them across several ATX & E-ATX motherboards without issue. As for the RAM, the sweet spot is 6000MT/s RAM where you run 1:1 with the FCLK and MCLK. Your 5600MT/s should work although technically, anything over 5600MT/s is an overclock.
I just order a set of the Corsair Titanium 6000MT/s CL30 RAM (2 x 32MB sticks) for an upcoming 9950X3D rig I'm building a) Is on the motherboard I'm using QVL, and b) Has both Expo & XMP
