When connecting PSU to the GPU, it turn on for half a second then breaks.
Checked PSU with jumper wire and it worked fine by itself.
Measured the GPU 8-pin connector and it peeped with 0 ohm between 12v and GND.
As in attached photo, I measured all these MOSFETS and the 4 caps and they gave 0 ohm too, the other 3 caps are good.
Don't know what to check farther as I don't have the diagram for this card.
Any guidance or advices would be much appreciated!
Thank you in advance!
https://linustechtips.com/topic/1612693-zotac-gtx-1660-amp-no-power/
