First Build - Would Like Some Insight
Go to solution Solved by podkall,
Big discount on the PSU, wow.
find these coolers:
Thermalright Peerless Assassin 120 SE
Thermalright Phantom Spirit 120 SE
MB:
ASRock B650 PRO RS
Gigabyte B650 EAGLE AX
ASRock B850 Pro-A
And CL30 RAM instead of CL36, doesn't matter which brand, see if CL30 RAM fits your budget.
But great list.
Budget (including currency): $1,000 USD
Country: United States of America
Games, programs or workloads that it will be used for: Light Gaming but want about 100 FPS, at least 1080p (idk if that is possible or not at this price in 2025 lol)
Other details I am upgrading from an Xbox One S so hopefully this is like a HUGE improvement, or maybe I'm just glazing the Console to PC switch experience lol.
 - I have a parts list on Newegg that I configured and wanted some insight on, this is my first build and really want to make sure I am getting everything right. There is no GPU b/c I plan to purchase a used 3060 Ti from a friend, I have seen it in person and tested it on his computer, it works just fine: https://newegg.io/f132c12
 - I am not totally set on anything other than the price give or take about $100 USD, I want it mostly black and  the more RGB the better
https://linustechtips.com/topic/1612627-first-build-would-like-some-insight/
find these coolers:
MB:
ASRock B650 PRO RS
ASRock B850 Pro-A
But great list.
current PC:
PC configs I used before:
Have you verified case and PSU compatibility? https://www.corsair.com/ca/en/explorer/diy-builder/power-supply-units/will-a-corsair-rmx-shift-psu-fit-in-my-case/
Consider a more capable CPU cooler.
What would you recommend? Do you mean I should go with an AIO or literally just a more capable air cooler
20 minutes ago, forss said:
I was thinking https://www.newegg.com/p/13C-000Y-000N0 or https://www.newegg.com/p/13C-000Y-000J3 which are less expensive and as good or better.
If you change to a dual tower cooler you should go with a low profile memory kit like (non RGB) Vengeance, Flare X5, or T-Create Expert.
4 minutes ago, forss said:
I made some changes that were recommended, here is the new list (GPU is being bought from friend, 3060 Ti used, good condition for about $200)
https://newegg.io/5a18e9d
I know I recommended that MB, but it's bit white for that black case.
Get one of these NVMEs instead:
SK Hynix Platinum P41
Acer Predator GM7000
990 EVO, is PCIe 5.0, and Pro RS doesn't have 5.0 slot, and the 990 EVO only has 2 lanes instead of 4, so when it slows down to PCIe 4.0 mode, it gets half the bandwidth a normal PCIe 4.0 NVME would get.
current PC:
Less expensive and will not force raising of the outer fan ~10 mm, https://www.newegg.com/g-skill-32gb-ddr5-6000/p/N82E16820374457?item=N82E16820374457.
Now I am in need of a monitor for my machine (https://newegg.io/5a18e9d)
I was able to find this ASUS TUF Gaming 27" Monitor that runs at 170Hz for $170 USD, would I be overpaying for this?
https://www.newegg.com/asus-vg27aqa1a-27-wqhd-170-hz-va-black/p/N82E16824281243?Item=N82E16824281243
I would prefer 144Hz above and no smaller than 27", I am going for a black theme aswell
The 3060 Ti is a gpu meant for gaming at 1080P due to card being limited to 8GB of VRAM. You don't want to exceed 25" at that resolution or your screen will look stretched (pixelated). The Corsair Shift psu's are meant for fish tank cases hence the reason the cable connections are on the side of that psu.
https://www.msi.com/Monitor/G244PF-E2
https://www.msi.com/PC-Case/MAG-FORGE-321R-AIRFLOW
PCPartPicker Part List
CPU: *AMD Ryzen 5 9600X 3.9 GHz 6-Core Processor  ($198.99 @ Newegg)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE ARGB 58 CFM CPU Cooler  ($39.99 @ Amazon)
Motherboard: *Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard  ($179.99 @ Newegg)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($92.99 @ Amazon)
Storage: *MSI SPATIUM M461 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ MSI)
Case: *MSI MAG FORGE 321R AIRFLOW ATX Mid Tower Case  ($79.99 @ MSI)
Power Supply: *ADATA XPG Core Reactor II VE 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Monitor: *MSI G244PF E2 23.8" 1920 x 1080 180 Hz Monitor  ($109.00 @ MSI)
Total: $890.93
Generated by PCPartPicker 2025-05-23 06:06 EDT-0400
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
Total: $890.93
Will the PSU still be compatible? I used the auto-compatibility feature on Newegg and it still showed up...
I assume it would be fine.
https://www.newegg.com/thermaltake-toughpower-gf3-series-ps-tpd-0750fnfagu-4-750-w/p/N82E16817153439
https://www.newegg.com/be-quiet-pure-power-750w-750-w/p/1HU-004H-000S3
I don't plan on buying everything right away, that is why the PSU is on back order. Not sure if Silicon SSDs are the most reliable, what is the general verdict with those? Any others you would recommend?
https://newegg.io/350da77
