I just recently upgraded my PC with in the past couple of days, including a new case. The case that I went with was the SAMA SV01, which is a fish tank style case and it came with 4 ARGB fans. Due to the amount of fans that the case has it has a built-in hub. All of the fans, including the GPU, it has RGB as well, are plugged in through the hub since it can help control fan speeds and RGB. The hub for the RGB is plugged into the ARGB header on my motherboard, which is a ASUS ROG STRIX B550-F Gaming. All of the fans are working and are powered, but I have no way of controlling the RGB. I have found similar threads on Reddit, which seemed like they have the answer, but I have not been able to fix it myself. On the case itself, it has a LED button, which some people have said to press and hold so the control goes to the motherboard, but I have not been able to get that working. Anyone who has any potential ideas or has a very similar set up, could you please let me know because I would like to be able to control the RGB, I know it’s not the end of the world, but I would like to.
