Hi I am looking at getting a 5070 ti they are both £799.99 so it's which is better for reliability Zotac or Gainsward.
I think Gainward for better cooling Vapour chamber
Gainward GeForce RTX 5070 Ti Phantom GS 16GB GDDR7 PCI-Express Graphics Card
Zotac GeForce RTX 5070 Ti Solid Core OC 16GB GDDR7 PCI-Express Graphics Card
My PC AMD Ryzen 3600, Vetroo V5, Nvidia 2060, Lian-Li LANCOOL II .
https://linustechtips.com/topic/1612567-zotac-or-gainsward-phantom-gs-for-5070-ti/
I would go with the zotac 5070 ti, the fan shroud doesn't look as cheap and I have a friend who has a zotac 4080 and has had no problems with it.
The Zotac RTX 5070 Ti Solid Core OC also has vapor chamber.
Both are solid options and you most likely won't be able to tell any difference between the cards in terms of temperature and noise levels. Performance will be identical.
The Gainward model is very solid, the most sold 4090 here in Norway was the Gainward Phantom 4090.
Get the one you like the most.
