Are liquid cooling fans able to be normal intake fans? Does that matter?
I'm looking to buy either the Asiahorse Cosmiq or the Asiahorse Dawn 120mm fans as front intakes. However Dawns seem to be labeled as just normal fans that can be linked together (which is one of the main things I want) to limit cable management, while the cosmiq fans are similar but apparently for AIO or liquid cooling systems. Can you use the Cosmiq fans as just normal intakes despite being for liquid cooling? Also do you have any other fan recs that are similar in the slide in connecting system, like the Lian Li fans? I was informed of the Cosmiqs by ZTT as sort of offbrand Lian Li wireless fans, and they do look nice. Idk if you'd need it for reference, but the case that I have is a Phanteks xt pro. I appreicate it!
Get Arctic fans rather than Chinese ripoffs
AIO fans are (usually) tuned for pressure instead of airflow. Nothing bad using them as case fans.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Gotcha. Do you have any recommended fans like the ones that I mentioned/style that I mentioned (that connect to each other)? The ones I've seen most are the Lian Li ones and jesus... I don't wanna spend over 100 bucks for that, like that's a bit much for me lol.
I like the Arctic P12 and P14 fans with PST (arctic's daisy chain tech).
PWM on them means PWM regulated, CO means Continuous Operation (for uses where the fans would always run).
43 minutes ago, VinSen said:
Do you have ones that can interconnect? I think at one point I was recommended the Arctic p12s...? Or something like that.
The PST variants can be daisy chained
P12 are pressure focused, there's the F12 for airflow
