Need advice on CPU/GPU
Solved by Grady_Smith,
I am personally biased toward Intel for the CPU, but if you are mainly focused on gaming, I would recommend an AMD processor. As for the GPU, I am definitely team Nvidia for multiple reasons, and because of that, I recommend the 5070, probably overclocked. I am actually looking at getting one for my upcoming build. Here is the best deal I have found: https://pcpartpicker.com/product/PxG2FT/gigabyte-windforce-oc-sff-geforce-rtx-5070-12-gb-video-card-gv-n5070wf3oc-12gd
LMK if that helps!
