Hello all,
I have a question thats been driving me mad so hopefully someone can help. I have Lian li infinity fans all around, all connected via their hub and have l connect installed as well. However I want to use Argus monitor to control the fans.
When i turn on MB RPM sync, all fans go to max and argus monitor doesnt control them, if i turn RPM sync on, them only L connect controls them.
What black magic do i need to do, so that i dont have to use the big L connect and have argus control them? Am i missing something obvious?
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/1612265-l-connect-3-with-argus-monitor/
Posted (edited)
connect the fans to the mb? the argus control im guessing is software for the mb headers? could be wrong thow
oh dose the fans have one connector? or 2? if its one then don't think it can be done. well atleast not plug and play...
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
