vibrating sound New CPU cooler is making a vibrating noise
Solved by W1ind3x,
On 5/17/2025 at 4:46 PM, leclod said:Ok, so to rule out the loose fin theory you could run only the middle fan.
If the noise remains then the cooler isn't your problem and returning it is useless.
So I replaced it with a thermalright peerless assassin. The sound is still there, but the thing is it's like 10x more quiet. I'm guessing that it's either turbulence or resonanse and because the thermalright fans are 500rpm less they create less of it. Eitherway I'm happy because I couldnt focus while working with the pure rock pro 3 installed. That sound really was unbareable to me.
