Hi friends.
Damn, for third time I am making mistake, buying aRGB fans which do come with controller but I always think that controller will do the job of making them aRGB.
Instead as usual, controller of the fans needs to connect to aRGB header on MoBo (which I don't have) to be able to have aRGB lights on fans.
Is there any option to get aRGB lights on fans if MoBo does not have aRGB header?
Any splitter, converter,special device of some sort?
So I want to have aRGB on fans, if not having aRGB header on MoBo.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
3 hours ago, frozensun said:
Hi friends.
there's this https://www.amazon.com/ARGB-Controller-Splitter-Computer-Control/dp/B0C3RJZC83?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A2AYFQ8VIZ6PZH&gQT=1
Posted (edited)
there's a converter for argb device to rgb controller not the other way around (was an option but its gone so plazable to do)
so you need a manual controller were you push the buttons on the controller or remote. have a hader on the mb or get an usb controller or program an arduino.
could buy rgb fans beat easier to control thow voltage but requires soldering. seems like alot of rgb stuff is gone now these days.
this is the cheaperest usb controller i have not tested it i had one but lost it some were...🤷‍♂️
something like this has some setting built in but remote is not too good and wont last vary long
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
