I've had a PC for some time now (https://pcpartpicker.com/list/crXbDj) and sporadically it will not turn on, which is becoming slowly more and more common when I hit the power button on the case, or even on the motherboard itself. The LED strips will light up, and the RGB memory closest to the CPU socket will also light up, but the power to the system does not start. If I hold the power button down for about 5-10 seconds, the lights will go out and then if I hit power again, the same thing happens. If I turn off the PSU, once the caps drain, all lights go out, and I can repeat the process over and over to no avail.
Then randomly, it will power on when I hit the button.
I've tried pulling the CMOS battery and replacing it. I've tried unplugging the 24 pin and plugging it back in, reseating ram and swapping power cables to new outlets. None of those steps changed anything.
Is my PSU going bad? Motherboard?
If I have to upgrade, I'd basically build a new system at this point and try to diagnose this one later as a hand-me-down or sell it for parts. I'd need a new PSU, mobo, RAM, CPU, case and cooler as my bespoke watercooling days are behind me with this one. Basically my drives and GPU would stay.
Delid 8600K @ 5GHz | Gigabyte Z370 Aorus Gaming 7 | 16GB Corsair Vengeance RGB | Gigabyte RTX 4070 Super Windforce OC | Phantex Enthoo Pro M SE | Samsung 990 Pro 2TB, 980 500GB, 850 500GB EVO, Crucial MX100 256GB, 3TB Toshiba P300 | Corsair AX750 OEM Sleeved | Gigabyte M34WQ | Custom Hardline Tubing: EK Supremacy + 240 Coolstream PE + DDC 3.1 Pump Res Combo/Extended Res/Meyhems Pastel White | Corsair K95 Platinum | Corsair M65 RGB | Bose Speakers + Beyerdynamic DT770 Pro + AKG K240 MkII + Shure 840 | W10 Pro | https://pcpartpicker.com/list/2JXbDj
