25 minutes ago, Can10efe said:
I have already but nth shows up
What is nth?
What motherboard / CPU / RAM do you have?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
Looks like an MSI motherboard. If so, these are the "EZ Debug LEDs". They light up if the mobo detects an issue. In your case it detects some problem with the DRAM. Check if all your memory is detected properly.
Where is the EZ Debug LED located
My MSI mobo also has the red LED lit up but since I don't notice any hardware or performance issues i've never bothered trying to fix it. Maybe it's some specific setting in the BIOS/UEFI.
How do you see DRAM?  Looks like the CPU light to me.
OnePlus Ecosystem:
Other Tech:
System is failing Power-On Self Test (P.O.S.T.).
Something wrong is detected on the CPU.
Has anything changed recently?
  • Remove the CPU Cooler?
  • Remove CPU from the socket?
  • Remove any of the RAM sticks?
  • Change to overclocks?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
I should try to refit the cpu then is that if?
5 hours ago, Can10efe said:
Nth means nothing sorry am British cpu is ryzen 7 9700x ram is Corsair vengeance 5600 32 gb ddr5 memory
Before you refit the CPU.... You say it's working?
What are temps?
How's performance?
OnePlus Ecosystem:
Other Tech:
What are temps?
How's performance?
The performance was normal temps normal and I have updated the bios and refit the cpu it was still working but with the light still on I really don’t know what’s wrong
Also today when I try to turn my pc on it will boot I get the motherboard screen but it won’t load into windows can someone please help
No much we can do.
If you've connected all power cables properly, the cooler properly, and don't have any bent pins...  you may have a defective part.  CPU or motherboard.
OnePlus Ecosystem:
Other Tech:
5 minutes ago, Dedayog said:
No much we can do.
Bro I have the pc running right now it won’t boot into windows for some reason after not using for one day but it was working the last time I used it but I can get into the bios no problem and in the bios the CPU is detected and works I really don’t know what’s going on the second red light is the boot which I don’t know why that’s not working
Have you messed with bios settings?
Can you load optimized defaults in the bios and try again?
OnePlus Ecosystem:
Other Tech:
I have not touched the bios also I got it run windows by rebooting over and over and leaving it for a bit it’s running normal but stilll got the red led
Btw is there an app for this am using the wed to get in here ?
Maybe Tapatalk?
Uhm, okay?  Not sure how to diagnose that.
I would personally reset bios, reinstall Windows, after I went over every power connector with a fine tooth comb.
Otherwise it's hard to say what's flaking, as you're working in a fashion.
OnePlus Ecosystem:
Other Tech:
