The difference is that one cant have any cables removed, one can have some cables removed and one can have all cables removed thus being non modular, semi modular and modular respectively
The PRICE difference is a whole other story and has no answer for all as its based on specific models, where you live and a whole bunch of other factors so check the prices on those as we cant answer you accurately on that one
What if YOU were cake all along?
Ok because I know I can get a semi modular and sell it for x. Thanx
9 minutes ago, Millios said:
rip. I meant I can sell how semi modular psu for x amount of money and a fully modular for y. The x and y are variables I want to find c. C=y-x. The difference in selling price between the 2.
Well then, YOU need to tell us what the price of X and Y are. We don't know where you are or what your prices are.
I will say though that semi modular are generally less desireable than fully modular, so that needs to be factored. If you buy a semi mudular, will you be able to sell it?
Ok then this applies
There is no set difference
[ Moved to Power Supplies ]
Modular - All the cables can be removed from the power supply.
Semi-modular - Some of the cables can be removed from the power supply. (The 24-pin is usually the permanently attached one.)
Non-modular - None of the cables can be removed from the power supply.
Which power supplies are we talking about here?
Whether or not a power supply is modular is not an indication of its quality. There are plenty of great non-modular power supplies, and there are plenty of modular power supplies that are actually cheap junk.
What's wrong with your current power supply? There's no reason to replace a perfectly functional power supply with a new one just because it does or doesn't have modular cables. That only makes a difference for cable management.
Don't buy stuff just for the sake of buying stuff.
Just for a future build.
Non modular is mess with all potential cables non removable
Semi is usually the sweet spot money and feature wise with all critical cables permanently affixed, and everything else removable
Fully modular is the ultimate, both in appearance and customization, it usually costs more, but many units have third party options for custom sleeved cables for epic aesthetics
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
A picture is worth 1000 words.
Non-modular, semi-modular, fully-modular. Left to right.
Modular Vs Non-Modular PSUs: The Battle Of Power Supplies
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Hmmm, You seem to be asking a different question in your title than in your first post.
Generally speaking fully modular are a bit more $$$, but as already noted doesn't really indicate quality.
80 Bronze certification or better and a 10 year warranty are a couple of things I look at first.
Read reviews and if the price seems too good to be true, be wary.
