Stuttering in every game(Looking for a solution)
Go to solution Solved by strange13930,
22 minutes ago, Liaml said:
In December I finally decided to build myself a pc. Since putting it together I have had serious stutters in every game I play. I have tried looking for solutions and many things I have seen suggest thermal throttling might be the issue. However my gpu and cpu temps stay around 65 under load. Afterburner does say that I am hitting the voltage limit of my gpu whenever it is under load. My GPU also has a noticeable coil whine that goes away when games stutter. The noise stops and then starts again when the game resumes. My CPU usage is well under 100 usage in every game and my GPU sometimes hits 100 percent usage but is normally closer to 85 percent. I have checked every core using afterburner and not a single core goes above 75 percent. In older games or less demanding games my gpu usage hardly gets above 50 percent and my cpu is around 20 percent but it still stutters. My average fps is fairly good in most games but my 1 percent and .1 percent lows are atrocious. My laptop has a 3050 ti mobile and it stutters less than my pc.
Here are my pc specs:
CPU: Ryzen 7 7700
Cooler: Thermalright peerless assasin
GPU: Gigabyte windforce oc Nvidia RTX 4070 super
Motherboard: Msi b650 gaming plus wifi
RAM: Crucial 2x16gb DDR5 6000 cl36
PSU: Corsair RM 750e power supply
Storage: WD black sn770 2tb nvme ssd
Case: Corsair iCUE 4000d airflow
Monitor: LG UltraGear 27GP83B 1440p 165hz
I have tried fixing it through.
-Updating my bios
-Updating my drivers
-Enabling/Disabling EXPO
-Disabling audio drivers
-Reseating my gpu and ram
-Increasing power limit in Afterburner
-Trying out different setting for vsync and gsync
-Changing my shader cache size
-Verifying integrity of files
-Disabling background applications
-Enabling resizable bar in my bios
-Using my monitor at 144hz instead of 165hz
Here is some benchmark results from afterburner in some games I've recently played
Psychonauts 2/1440p/Very high setting/Resolution scaling 100
13-05-2025, 16:25:28 Psychonauts2-Win64-Shipping.exe benchmark completed, 44044 frames rendered in 222.719 s
                     Average framerate  :  197.7 FPS
                     Minimum framerate  :   72.5 FPS
                     Maximum framerate  :  831.3 FPS
                     1% low framerate   :   54.2 FPS
                     0.1% low framerate :    1.7 FPS
Psychonauts 2/ 1080p/ Very low/ Resolution scaling default
13-05-2025, 17:27:13 Psychonauts2-Win64-Shipping.exe benchmark completed, 27848 frames rendered in 101.578 s
                     Average framerate  :  274.1 FPS
                     Minimum framerate  :   43.9 FPS
                     Maximum framerate  :  368.0 FPS
                     1% low framerate   :   40.0 FPS
                     0.1% low framerate :    1.2 FPS
Spiderman Remastered/ Native 1440p/ Very high settings/ Ray tracing off/
13-05-2025, 16:10:33 Spider-Man.exe benchmark completed, 20623 frames rendered in 124.031 s
                     Average framerate  :  166.2 FPS
                     Minimum framerate  :  105.5 FPS
                     Maximum framerate  :  230.6 FPS
                     1% low framerate   :   71.8 FPS
                     0.1% low framerate :   27.9 FPS
Spiderman Remastered/ Native 1440p/ Very low settings/ Ray tracing off/
13-05-2025, 17:34:17 Spider-Man.exe benchmark completed, 20377 frames rendered in 118.656 s
                     Average framerate  :  171.7 FPS
                     Minimum framerate  :  119.2 FPS
                     Maximum framerate  :  249.4 FPS
                     1% low framerate   :   88.9 FPS
                     0.1% low framerate :   26.3 FPS
ULTRAKILL/ 1440p/ Default settings/ vsync off
13-05-2025, 16:40:52 ULTRAKILL.exe benchmark completed, 47696 frames rendered in 71.453 s
                     Average framerate  :  667.5 FPS
                     Minimum framerate  :  348.6 FPS
                     Maximum framerate  : 1565.8 FPS
                     1% low framerate   :   76.7 FPS
                     0.1% low framerate :    3.0 FPS
ULTRAKILL/ 1440p/ Default settings/ vsync on
13-05-2025, 16:47:59 ULTRAKILL.exe benchmark completed, 14856 frames rendered in 90.609 s
                     Average framerate  :  163.9 FPS
                     Minimum framerate  :  108.7 FPS
                     Maximum framerate  :  166.6 FPS
                     1% low framerate   :   78.5 FPS
Portal 2/ 1440p/ Max settings/ 4x msaa
13-05-2025, 17:38:28 portal2.exe benchmark completed, 17582 frames rendered in 60.531 s
                     Average framerate  :  290.4 FPS
                     Minimum framerate  :  247.7 FPS
                     Maximum framerate  :  292.9 FPS
                     1% low framerate   :  211.0 FPS
                     0.1% low framerate :   10.7 FPS
Portal 2/ 1440p/ Max settings/ 8x msaa
13-05-2025, 17:41:21 portal2.exe benchmark completed, 33128 frames rendered in 114.047 s
                     Minimum framerate  :  255.6 FPS
                     Maximum framerate  :  292.8 FPS
                     1% low framerate   :  230.2 FPS
                     0.1% low framerate :   28.0 FPS
I am looking for advice on possible solutions. This is the first pc I have built and if I didn't have a laptop that ran games more smoothly then I might not have even realized that this is a problem. But now it is making me frustrated and not want to play games. I almost exclusively play single player games and I have had the same experience in every game.
chipset drivers? you can try DDU and then reinstall your drivers to one around December of last year.
CPU: Ryzen 7 7700
-Updating my bios
CPU: Ryzen 7 7700
-Updating my bios
Fast startup turned on?
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Thank you so much this seems to have solved most of my problems. I think I will also do a clean windows install once a get a separate ssd for my game library.
1 hour ago, FCBoi said:
my last resort would be a clean windows install from a new storage. Works like a charm
Thanks for the advice. I think I got it fixed mostly for now, but I'll probably do a fresh install when I get a separate ssd for my game library.
