gpu cable connection state.
By
Aragorn1
in Power Supplies
in Power Supplies
Solved by cat_B0T_Gaming,
You should be OK, but I am noticing a little bit of GPU sag, so pop a sag bracket in. Good luck with that power connector, though. Be careful with that power connector, as it may just melt. You should be OK in the short term
spekky ·
Posted in Troubleshooting0 -
bryan0315 ·
Posted in Graphics Cards1 -
1
1
RayNzz ·
Posted in Storage Devices2 -
Firstgo111 ·
Posted in New Builds and Planning5 -
3
biswadip.sh ·
Posted in Audio2
play_circle_filled
Latest From Linus Tech Tips:
Companies are Suing Honest Reviewers and it’s Going to Get UGLY.
