upgrade ideas and info
Go to solution Solved by brob,
7 hours ago, taxi said:
as for the case i have a MSI mag Forge 121A airflow
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (€406.90 @ Amazon France)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (€46.99 @ Amazon France)
Motherboard: Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard (€157.09 @ Amazon France)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€118.49 @ Amazon France)
Storage: Crucial P1 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (Purchased For €0.00)
Video Card: Asus PRIME OC GeForce RTX 5070 12 GB Video Card (Purchased For €0.00)
Case: MSI MAG FORGE 321R AIRFLOW ATX Mid Tower Case (Purchased For €0.00)
Power Supply: be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€120.53 @ Amazon France)
Total: €850.00
Generated by PCPartPicker 2025-05-14 14:27 CEST+0200
Budget : 800 euro i can probably get it up to 1300
Country: france
Games, programs or workloads that it will be used for: gaming (i play a loot of games from all type of genres)
Other details: i bought a prebuild but didnt really inform myself at all the specs are as follows
cpu: ryzen 5 5500
gpu: RTX 5070 12gb
ram: 16gb of ddr 4
ssd: 1tb
ram: one stick of 16gb
psu: 650 w 80+ bronze
motherboard: A520
those are the i know im a noob and was really afraid of buying the pieces on my own my friend said that the current build needs some upgrades
i was thinking about a new motherboard that can take AM5 cpus and ddr5 ram however i dont know what kind of cpu i should get to not bottleneck my gpu witch i think it is already
i also dont know if its in my budget
all this was also done with my own research on the internet so i dont know what to buy and im still very unfamiliar with pcs
i initially bought a prebuild because i dont know how to change pieces but ill probably talk to one of my friends about that
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€406.90 @ Amazon France)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€41.90 @ Amazon France)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard  (€205.88 @ Alternate)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€104.88 @ Alternate)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€110.00 @ Infomax Paris)
Total: €869.56
Generated by PCPartPicker 2025-05-12 03:54 CEST+0200
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/#findComment-16725538
Country: france
cpu: ryzen 5 5500
gpu: RTX 5070 12gb
ram: 16gb of ddr 4
ssd: 1tb
motherboard: A520
It would be helpful to know some details of the case.
The motherboard sizes (likely ATX or M-ATX) that can be housed in the case. Easiest way of determining this is to count the expansion card opening on the rear. Six or more, usually 7, the case is ATX. Less than 6 the case is likely M-ATX. (1 - 3, the case is mini-ITX.)
The other important dimension is the maximum CPU cooler height. A measure from the top of the motherboard to the inner side of the left panel is a decent approximation.
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/#findComment-16725728
from what i can see its 4 screws
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/#findComment-16726922
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/#findComment-16726952
Total: €850.00
https://linustechtips.com/topic/1611704-upgrade-ideas-and-info/#findComment-16727118
