PC surging power to keyboard after switching mobo
What happened is most likely a power surge from the electrical system of the house. Not much can be done about it except call an electrician and contact the power company.
As for your PC, it doesn't look good but maybe you can save some parts. Computers have many layers of protection so it is likely something survived despite the light show.
If you don't like or want to work on your PC components, you should ask a friend or a repair shop to do the following suggestions in your stead.
First, don't plug your PC. That is a safety precaution and to prevent further damage.
I'd completely disassemble the PC and remove the parts from the case. Remove all cables and even remove the RAM, the CPU and the GPU from their sockets.
Set the motherboard and PSU aside for later.
Next step is to test every component one by one in another computer to rule out which one is defective and which one is still working.
The PSU can be tested but if I were you I'd simply never use it again. If it is still working, it probably became more unreliable due to the surge it experienced.
As for the motherboard, if no other components did burn then you can try assembling the computer again. If other component failed then I'd assume that the motherboard suffered damage too and it may be for the better if you change it.
Hope that helps.
