Hello,
I just build a new PC including a Gigabyte X870E Aorus Pro motherboard and a Gigabyte 5070 Ti Gaming OC graphics card.
The graphics card is huge and the motherboard has large cooling plates and whatnot, but I am pretty sure it is inserted correctly. Their was an audible "click" when the graphics card was installed and it aligns perfectly with the backplate. I also made sure to slide the click-device-thing before installing.
The graphics card is not identified in BIOS or Windows 11. Fans and RBG are running on the GPU. It gets power directly from the PSU via a 600 W PCIe.
I have tried "using" device manager to find it, but without any luck. Also tried to install a graphics card driver from nVidia, but the GPU wasn't detected.
Any recommendations on how to tackle this issue are welcome and much appreciated.
The thing has a dual BIOS mode. Check for a manual switch on your card.
Update the motherboard BIOS for a good measure.
"The GB8/12 Liberation Front"
Refresh before you reply
7 hours ago, Mark J. said:
Hello,
check your pcie function in your bios, it might be turned off or set for a expansion card, can always pull th  card inspect the slot and card and all plug if its not the bios
Many thanks.
I updated the BIOS to the newest version.
The card has a manual switch but that is for toggling between silent mode and performance mode. Should I try toggle it nonetheless?
I checked in BIOS. It is set to use the PCIe1 lane as default.
Sometimes a device is listed as a peripheral in connection with the PCIe lane. Perhaps it is not shown as a graphics card as such because no NVidia drivers have been installed?
Perhaps I should note the following which may be a correlated issue.
I keep getting black screens or BSoDs when entering Windows.
First time this happened I had just installed drivers for the motherboard in this sequence: completely fresh first time install of Win11 > All Win updates > MB drivers.
Afterwards I wiped the drive and did a complete fresh install (nothing else worked) following the above sequence, except I flashed the BIOS right after installing Windows and Windows updates. Again I got black screens and BSoDs after installing drivers for the MB.
Sadly the issue persists and I am at a loss. The problem seems to occur only after installing drivers for the motherboard.
Perhaps it could be an issue with a specific driver (likely the graphics card driver for the MB?), or a compatibility problem between certain Windows updates and a driver?
Perhaps others have had similar issues.
Thinking that I should try and install all MB drivers, one at a time, and perhaps refrain from installing the onboard gfx driver and see what happens.
39 minutes ago, Mark J. said:
Many thanks.
pcie is set as 16xs? tried diffrent display port and cable?
what gpu, who makes and model?
I tried using display port instead of HDMI. Plugged it into the graphics card and viola! problem solved.
Thank you!
