Recommended power supply for a system with a 8700k and no gpu?
Solved by Hinjima,
3 minutes ago, Mr. Rosa said:Im putting together an old system for my parents and I have all the parts I need but the power supply, so I would be greatful for any suggestions at to what watt power supply to get for it. Thank you
specs:
I7-8700k
no gpu
atx mb
16gb ram
one ssd
one hdd
couple fans
would a 350 watt work?
a 350w would work but most 350w power supplies are absolute garbage.
I can recommend a MSI A550BN, its way overkill in terms of power but its the cheapest PSU I can recommend that is reliable and safe.
Most other cheap 300-450w PSU's from companies like Apevia or NOX are just a fire hazard.
