Need Help Configuring my First PC, High End (~3500€)
8 hours ago, Crowlog said:Budget (including currency): ~3500€
Country: Austria
Games, programs or workloads that it will be used for: Mostly gaming and some 3d stuff like Blender too. Games are both big AAA titles as well as smaller indie games.
Other details: This PC has to be built from the ground up as it's my first one. I would also like to purchase a second screen (2560x1440, 165Hz) so if you know some good ones, pls tell me. The systems needs to run Windows.
My Configruation
I already put some thought into what I would like to have. I would need your advice on if there are any problems with the configuration or things I have to look out for when building. I'm completely new to pc building so improvements are very appreciated.
This is what I have: PCPartPicker Part List: https://pcpartpicker.com/list/4xFYqH
CPU: AMD Ryzen 9 9950X 4.3 GHz 16-Core Processor
CPU Cooler: NZXT Kraken 360 78.02 CFM Liquid CPU Cooler
Motherboard: MSI MAG X870 TOMAHAWK WIFI ATX AM5 Motherboard
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6600 CL32 Memory
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Asus PRIME OC GeForce RTX 5080 16 GB Video Card
Case: NZXT H7 Flow (2024) ATX Mid Tower Case
Power Supply: MSI A1000G PCIE5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan: NZXT F120Q (2024) 74.26 CFM 120 mm Fan
Thanks in advance![]()
DDR5-6000 CL30 (AMD EXPO certified) RAM so that you don't have issues getting your rated timings. ATX 3.1 psu, case with better airflow that's easier to build with, especially if using an AIO.
https://geizhals.at/msi-mag-b850-tomahawk-max-wifi-7e62-002r-a3383450.html
https://www.msi.com/Motherboard/MAG-B850-TOMAHAWK-MAX-WIFI
MSI MAG B850 Tomahawk Max WIFI €239,00
or ....
https://geizhals.at/asus-tuf-gaming-b850-plus-wifi-90mb1j30-m0eay0-a3381526.html
https://www.asus.com/us/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b850-plus-wifi/
ASUS TUF Gaming B850-Plus WIFI €238.91
https://geizhals.at/amd-ryzen-9-9950x3d-100-100000719wof-a3381558.html
https://www.techpowerup.com/review/amd-ryzen-9-9950x3d/
AMD Ryzen 9 9950X3D €782,90
https://geizhals.at/arctic-liquid-freezer-iii-360-acfre00136a-a3128759.html
https://www.arctic.de/us/Liquid-Freezer-III-360/ACFRE00136A
Arctic Liquid Freezer III 360mm AIO €85,99
https://geizhals.at/kingston-fury-beast-schwarz-dimm-kit-64gb-kf560c30bbek2-64-a3164913.html
https://www.kingston.com/en/memory/search?partid=KF560C30BBEK2-64
Kingston FURY Beast DDR5-6000 64GB (2x32GB) CL30 €195,88
https://geizhals.at/samsung-ssd-990-pro-4tb-mz-v9p4t0bw-a2798124.html
Samsung 990 Pro 4TB M.2 PCIe 4.0 x4 NVMe SSD €289.90
https://geizhals.at/gigabyte-geforce-rtx-5080-windforce-oc-sff-16g-gv-n5080wf3oc-16gd-a3381809.html
https://www.gigabyte.com/Graphics-Card/GV-N5080WF3OC-16GD#kf
GIGABYTE GeForce RTX 5080 Windforce OC SFF 16GB €1279,67
https://geizhals.at/fsp-advan-gm-1000w-atx-3-1-advan-1000gm-ppa10a4200-a3420420.html
https://www.fsplifestyle.com/en/product/ADVANGM1000W.html
FSP ADVAN GM 1000W ATX 3.1 €131,47
https://geizhals.at/lian-li-lancool-216-a2847029.html
https://lian-li.com/product/lancool-216/
Lian Li LANCOOL 216 ATX Mid Tower Case €106,95
Total: €3120,86
https://geizhals.at/lian-li-staubfilter-set-fuer-lian-li-lancool-216-lan216-2x-a2948069.html
Lian Li Staubfilter Set für Lian-Li LANCOOL 216, schwarz €15,03
https://geizhals.at/microsoft-windows-11-home-64bit-multilingual-pc-a2615378.html
Microsoft Windows 11 Home 64Bit, DSP/SB, ESD (multilingual) €36,67
or ....
https://geizhals.at/microsoft-windows-11-home-64bit-deutsch-pc-kw9-00638-a2611664.html
Microsoft Windows 11 Home 64Bit, DSP/SB (deutsch) €36,00
https://geizhals.at/asus-tuf-gaming-vg27aqml1a-90lm05z0-b07370-a2981641.html
https://www.asus.com/us/displays-desktops/monitors/tuf-gaming/tuf-gaming-vg27aqml1a/
Asus TUF Gaming VG27AQML1A 27.0" 2560x1440 260Hz 1ms IPS Monitor €339,10
