Dear Users,
I have a seagate personal cloud model = STCR4000301.
Segate Personal Cloud Storage 4 TB 0
I had this device for 5-6 years but never used it. I tried to connect it recently and found out that seagate NAS OS is obsolete.
I found the seagate media app apk file on the internet and tried to connect my personal cloud with it but no luck.
I can access the web page over the local network but can't upload data on it.
The only way I can upload data is through network drive.
How can I use this device as a proper NAS? Can I still use the NAS OS and its apps if I found their APKs ?
Can I somehow wipe the obsolete seagate NAS OS and use some freeware or something else?
Kindly guide.
regards
https://linustechtips.com/topic/1610232-seagate-nas-os-obsolete-issue/
Either just use it was a network drive via SMB or replace it. It seems like it has gone EOL so no more seagate support, and seems like there is no easy way to get a different OS on it. It might be possible to change the firmware on it, but its likely not x86, and likely not a easy process.
Thanks electronics wizardy.
If i stick with EOL NAS OS. Will it be possible for me to use SMB apps to access my personal cloud over the internet?
I tried some apps but can't get them started. Didn't put that much effort into it.
But if this is possible I can try that around.
Regards
Regards
You really don't want to exposre smb over the internetl, esp on a eol device. A VPN should work thoughl
