If anyone has a solution until Nvidia fixes it.
Frame graph not stable after driver 572.16 or newer. Game feels like 20 fps with FrameGen on.
566.36. driver Everything is fine. Its same in every game with frame gen.
Problem with older driver is i cant override dlss and framgen version in Nvidia App. Since i have a laptop RTX 4060 if i keep it on Optimus its ok with new driver but i dont have G Sync, but i turn on Intel Smooth Sync as an alternative. If anyone knows a solution for unstable running wit frame gen on newer nvidia drivers feel free to help.
P.S. I have submitted a ticket to Nvidia about the problem, ill update you with details of their answer.
UPDATE (4/5/2025)- Nvidia said to wait for newer drivers........ current 576.28 does not fix the issue.
Problem with older driver is i cant override dlss and framgen version in Nvidia App. Since i have a laptop RTX 4060 if i keep it on Optimus its ok with new driver but i dont have G Syn, but i turn on Intel Smooth Sync as an alternative. If anyone knows a solution for unstable running wit frame gen on newer nvidia drivers feel free to help.
it's probably them trying to fix a problem and then creating 3 more, it will probably be a few driver updates till they fix it. I would stick with the older driver for now.
Figures, im on newest actually 576.15, i just use in with Optimus(Frames go trough Intel UHD) i dont have g sync that way but i can live with that for now. Hope they just fix it......
