Thank you AMD for sponsoring this video and being a great partner! Check out their latest gaming offerings below!
AMD Ryzen 9 9950X3D CPU: https://geni.us/eR9W0
AMD Radeon RX 9070 Graphics Cards: https://geni.us/SqHcKy
AMD Radeon 9070 XT Graphics Cards: https://geni.us/DN35
What happens when you connect a Fire Truck to a PC water cooling loop? Well given PC water cooling fittings are rated for about 8psi and the Fire Truck can do over 200psi… I think you can see where this is going.
You stepped down a 4 inch hose to a 1/8 inch hose when a standard heat sink is 2 inches?
Also, next time cool a reservoir and/or the fittings.
Also, maybe consider using the fire hose to power a smaller pump instead of directly using the fire water.
